Hehe, it seems we surf the same sitesdr.occa wrote: we read the same write up in regards to the bmw COPs setup cribbj!
i borrowed your diagram and altered it for an EDIS 4 application (my application) and applied the in-series configuration. i have another EDIS4 module i could always hook up in parallel but am hoping the single EDIS will suffice. i also wasn't sure about the secondary grnds on the COPs so i did not address them in the attached diagram. any insight would be greatly appreciated.
The fellow who ran the BMW coils in series was good enough to reply to an email I sent him and he confirmed the circuit worked fine, and he hadn't encountered any misfiring at higher RPM's. Conventional wisdom would lead you to think since you've doubled the resistance, and halved the current, that perhaps there wouldn't be enough dwell time at high RPM to fully charge the coils, but maybe this isn't the case, or perhaps he just wasn't stressing the ignition system.
You mentioned secondary grounds on the COP's - what are you referring to? Is it possible your COP's have integral ignitors?
