Endless timeouts!!!!
Thanks, that helps. When you get together with your brother go over the troubleshooting guide, here:
http://www.autosportlabs.net/Troublesho ... lt_Lite_Jr.
This is further low-level testing you can do. Please report back!
mikee
Post by mikee »
I managed to get another laptop with a serial port ..... but still nothing!
My brother tried for a couple of hours and gave up... but did mention that there maybe buffer chips that can blow.....Make any sense?
Still waiting for my timing light.
Mikee
mikee
Post by mikee »
How do i get to the hyper terminal? ... can't find it anywhere..
M
Mikee,
Hyperterminal may not be installed on your version of windows- it used to be commonly available on previous versions of windows.
You can download a free trial version here:
http://www.hilgraeve.com/hyperterminal.html
mikee
Post by mikee »
Thanks Brent ... i understand now!!! :oops: Timing light should arrive tomorrow..I'll let you know how i get on... Thanks for being patient.
Mike
Of course.. we want you up and running ASAP- and we think you're the one being patient, actually- so thanks too :)
mikee
Post by mikee »
Timing light has arrived and i've just tried it ...... No movement at all, must be running on edis default!
mike :?
mikee
Post by mikee »
Just tried using Hyperterminal..................Nothing happens!
Made up a completely new lead ...........Nothing
Diferent pc....................Nothing
Took everything off my laptop and tried it all again................Nothing!
Mike :? :cry:
mikee
Post by mikee »
BIG hammer on standby!!!!!
mikee
Post by mikee »
Update.... Hammer has been put away.!!
Tried doing that wiggling and tugging at wires etc and at one point i did get a response!!
:idea: loose conections to the back of the rj11 socket, Next job is to disconnect and check that out..........
Mike
mikee
Post by mikee »
Been trying for 2 hours and still not working ...............Any more ideas?
Funky Diver
Post by Funky Diver »
Did you check for dry solder joints on the RJ11 socket?
mikee
Post by mikee »
I looked and nothing was loose so i guess it's ok.... would it hurt if i dabbed a bit more solder on the connections?
Mike
mikee
Post by mikee »
Well ...........I did it anyway! and it seems to have worked :D :D
I'll have a play tomorrow ,when the fumes have cleared, and see if i can get things running a bit smoother...!
Fingers crossed!
Mike :D
mikee
Post by mikee »
Brilliant !!...........it's worked all day.. :D Thanks soooo much for all your help, it's been invaluable.
I was so close to trashing the thing on a number of occasions....Glad i didnt now.. :oops:
Next step.... rolling road to set things up
Regards Mikee
