Tachometer Adapter board
This would be no different than a properly made home-made diode circuit.
Could you describe your problems? Does it always read low RPMs? If not, does it read exactly 1/2 RPMs when it's exhibiting the problem?
73tii
Post by 73tii »
hello Brent,
Tach was efficient for a few weeks but the problem became more consistent over time. but yes..reading is consistently low now.
below is how I did my circuit.
tach diode fix.jpg (9.32 KiB) Viewed 27129 times
73tii
Post by 73tii »
is it possible the diode is shot? anyone?
We're not familiar with that circuit design- it's different than what we have, but it seems that it could work. You might want to check connections on the diodes - if all connections are good it's possible one of the diodes might need replacing. Replace both just to be sure.
Make sure you're using diodes rated for at least 400V - like a 1N4004 or equivalent.
73tii
Post by 73tii »
found a short in the wiring which subsequently affected the tach to be lazy. All is well now. Thanks Brent.
essexstu
Wiring
Post by essexstu »
Good morning, before attacking my wiring loom, wanted to check where to place the circuitboard i just recieved. Im running a v6 with wasted spark and an after market ecu - Vi-PEC (the same as link). My tacho is a standard Ford one and expecting the 400v, but the aftermarket ecu only puts out 12v.
Understanding the circuit board needs the 3 pulses, but does it need the 3 pulses from the ecu (low voltage) or the 3 pulses after the ignition amplifier that go direct to the coils?
Many thanks
The board is designed to tap off of the drive lines for the coil packs - after the ignition amplifier you have.
essexstu
Post by essexstu »
Worked a treat thanks :-)
That's great to hear! Thanks for the feedback.
