Keep me in mind, OK?
I have a couple of suggestions for the configurator software based on my experience using it with a tablet. Should I post them here, or is there a better thread for that?
Trying to connect via Bluetooth.
bobclevenger
- Contact:
Back on topic again after a long time. Finally success but unfortunately not on my good old XP pc's. On every 3 of them the connection comes in at COM40. As the Administrator password I know doesn't work in Safety Mode I can't delete COM ports with a lower number. No way to change COM40 either; I tried the tricks suggested but nothing goes. Another option, the use of a program where you can mess with virtual COM ports and connect them gave no positive results either (yet).
On the other hand, there was positive result on my newer Windows 7 job laptop. After finding the switch for the Bluetooth device (never used before on that machine) and installing the MJ software the whole circus fired up at once
. Bluetooth connection came in at COM5, so no connection trouble at all. Maybe time to look for a cheap used Windows 7 Laptop or (maybe even better) a small tablet if the MJ software can run on that.
Alex
Alex
bobclevenger
- Contact:
