LandRover 2.25l 4-cylinder
Post LandRover 2.25l 4-cylinder
Engine Mfg: Land Rover
Engine Code:
Cylinders: 4
Displacement (cc): 2286
Rev Limit:
TPS or MAP: MAP
Boosted or Normally Aspirated: N/A
If Boosted- max Pressure (KPa):
Modifications:
Chassis:
Notes: A basic map for a 2.25l 5 bearing series Land Rover engine - although it may also be a starting point for earlier engines too. It was designed to replicate the advance curve of the Ducellier distributor fitted to later vehicles. No further tuning has been attempted. This map seems to make my engine run very happily indeed.
You can find out more about my installation by visiting: http://otly.mysite.orange.co.uk/
2_25_LandRover_1.cfg
 Description:
Download
 Filename:  2_25_LandRover_1.cfg
 Filesize:  781 Bytes
 Downloaded:  939 Time(s)
