vw 16v kr with carbs map wanted please.
Post vw 16v kr with carbs map wanted please.
hi all im new to the forum and megajolt but really interested in it, basicly im after a base map or something higher for mw vw golf. engine wise its a 2.0l 16v kr lump with zx9r bike carbs and tps, any help would be muchly appriciated!
cheers Ash
vw golf 2.0 16v zx9r carbs
here are a few maps i run in my vw, these are original base maps that i changed to suit, i have used all 3 but find that no. 2 works the best for my set up. this is with tps.
engine spec..
vw 2.0 16v 9a standard block
vw golf mk2 kr 16v head mild port and polish
276 deg. inlet & exhaust cams
4 branch exhaust manifold with 2.5 inch system
dcoe 40 weber carbs , 36 vent. 145 main. f16 tube, 190 airs, 55f9 idle,45 pump, 4.5 aux. vent.
golf fix3.mjlj
 Description:
as 2 but with a small change
Download
 Filename:  golf fix3.mjlj
 Filesize:  725 Bytes
 Downloaded:  948 Time(s)
golf fix1.mjlj
 Description:
this was the first attempt
Download
 Filename:  golf fix1.mjlj
 Filesize:  725 Bytes
 Downloaded:  858 Time(s)
golf fix2.mjlj
 Description:
this is what i run now.
Download
 Filename:  golf fix2.mjlj
 Filesize:  725 Bytes
 Downloaded:  1072 Time(s)
great stuff, i'l give em a go once im up and running, just needed an idea to look at. my engine is similar spec should be pretty close.
how do you find the megajolt? much more improvement over the dizzy setup?
thanks for the maps i'l let you know how they run!
there is no comparison with the original ignition for relibility and performance, and the ability to switch to another map is great, i run normally 95 unleaded but when in germany 100 octane is available from the pump. so a map with more igniton advance, more performance, there is the autobahn after all, it would be a shame not to Very Happy
great cant wait to get it running now, think im gonna be using 98 super unleaded as its not a daily driver. 100 octane would be nice tho! what sort of power are you running then, and what cams? there next on my shoppin list!
file update 2017
std. abf 2015.mjlj
 Description:
This file is almost a copy of the factory abf map i found and adapted it to fit the megajolt software and runs really well and prevents the revs dropping too low when up-shifting above 4krpm.
Download
 Filename:  std. abf 2015.mjlj
 Filesize:  705 Bytes
 Downloaded:  157 Time(s)
june 2017.mjlj
 Description:
this map runs well but lacks advance under 3krpm but fit well with a high comprerssion engine to prevent knock at wot under 3krpm
Download
 Filename:  june 2017.mjlj
 Filesize:  706 Bytes
 Downloaded:  153 Time(s)
hi ,and thanks ,i use you're "golf 3 fix" file in my kr (1.8l) with 82 mm pistons and p"p head with ferrea valve .
it works well but my setting of dcoe etc create a missfire in one cylinder (?..)
Thanks VR6, just download and am giving it a try now!
