Engine Mfg: MGB
Engine Code
Cylinders:4
Displacement (cc):1086
Rev Limit:7000
TPS or MAP:TPS
Boosted or Normally Aspirated:Moss Supercharger with small pulley
If Boosted- max Pressure: 7.5 PSI
Modifications: Low compression build 8:1 compression ratio
Chassis: NG TC
Notes: Requires setting up on dyno for refinement. This MAP is revision 6 and has taken many hours and experimentation to get this far.
MGB Engine with Moss supercharger TPS MAP
- NG TC SC FTbased rev 6 Fri 18 Jan.mjlj
- (714 Bytes) Downloaded 1014 times
- Contact:
