which tps
rich
which tps
Post by rich »
which tps would i need to suit a 45 dellortos, have found a company advertising one to fit but they want £60 for it , is this pricey.
cheers
rich
MartinM
Post by MartinM »
rich
Post by rich »
thanks for that, seems a mondeo tps can be adaped to fit as sixty quid for one i have found is a bit steep i feel.
other question i have is how i can fit the ford ht lead connector to sprint leads as they have a long tube fitted to lead, as the plugs are deep in the cylinder head.
rich
For some HT lead configurations you may need to make a set of hybrid ignition cables- use the spark plug ends from your original setup, and adapt the snap-on connectors for the Ford coil pack. Usually you can pry apart the crimped connector from connector end or the other, resulting in a custom set of cables. In the process you can make your own custom cable lengths!
