New member - First post so go easy on me
I just installed the Megajolt and Edis 4 setup in my 1132 A-Series Mini Turbo.
Wired up correctly (not 100% sure on the VR Sensor polarity though) and the power to the EDIS + Megajolt.
Ill explain...
I got everything hooked up and tried to crank it, it turns, but wont kick... not even trying.
The thing I notice is that the MJ4 has a green 'Power' LED on it. When I am on AUX or Key to 'ON' its green (so its powered on) when I am 'cranking' the light turns off.
Should it have power during cranking? I presume so... ill try to fix it.
The EDIS and coilpack are powered from that same source.
Also, how can I check VR sensor polarity is on right?
This is my checklist this afternoon
1. Check I am getting spark from coil
2. Disconnect MJ and see if it runs with EDIS in Limp mode
3. Feed 12v power to MJ and EDIS from original coil power (that used to work so should still)
4. If the above all prove to be OK, but still no kick, ill swap VR sensor wires and try again.
I hooked up the MJ to the laptop and it all works ok... anything I should check in the program?
Any other tips or advice to look at this afternoon?
Peter
PS: Brent - Brilliant product mate but bne thing I would have loved - If the Megajolt already had a short wiring loom attached so we dont have to crimp our own Molex plugs...
