Reply to topic Page 1 of 1
Two EDIS6 controllers for V12 engine?
Post Two EDIS6 controllers for V12 engine?
A large group of Jaguar V12 owners are interested in converting to coilpack EDIS
ignition since the original Jaguar V12 ignition system is fragile and unreliable as
well as being severely limited by old technology. One gentleman in South Africa
has mounted two VR sensors 60 apart along with the required 36-1 toothed
wheel on the front of his V12 but he had to specially design and fabricate a custom
circuit board that would delay the outputted SAW signal for the second EDIS6
controller by 60 since there is no provision to work with multiple EDIS controllers
with the current megajolt (ignition only) or megasquirt (ignition & EFI control)
implementations.
Also there really is not much room on the front of the Jaguar V12 engine for two
VR crank sensors to be mounted 60 apart so it would be really beneficial to be
able to simulate the second VR sensor signal for the second EDIS controller from
the first VR sensor signal since it is the same signal delayed by 60
Is any of this possible in the current or future versions of the megajolt product?
Steven DuChene
View user's profile Send private message AIM Address Yahoo Messenger
Post
I have some updates due on our Megajolt2 plans. At minimum you need a system with 6 coil drivers in a wasted spark setup- 12 in a true Coil on Plug configuration. I think our plans will include something that can fit your needs. Check back in a day or two!
_________________
Founder, Autosport Labs
Post
Wasted spark with coilpacks would be a HUGE improvement over what we have now so for right now the coil-on-plug stuff is over kill.
Thanks for the fast response to this question however.
Steve
Post
Agree, coil-on-plug really shines for very high RPM applications, or if you want to use the convenient coil-on-plug modules with built-in drivers.
_________________
Post where MJ2 info at?
BTW, where do I look on this or the other autosport labs sites for information on the Megajolt2
units? And what is your expected release schedule for that? Having a real possibility of doing
coilpack ignition on the Jag V12 engine is eagerly anticipated!
Post
There hasn't been anything official yet, that's what I was alluding to in my initial reply.
_________________
Post
But will you be posting the information under the News & Announcements part of the forum or on
one of the other parts of your Autosport Labs sites?
Post
Yes! Smile
Post Justin McLeod
BTW, I am the person who got the circuit diagram for the saw delay circuit from the guy in South Africa to Justin.
Justin says your wasted spark solution for V12 cars is somehow based around that.
Post Re: Justin McLeod
That's not familiar to me. The Megajolt2 family will not require an EDIS module and will therefore not need a SAW delay circuit.
_________________
Ah, OK
I must have misunderstood Justin's IM notes.
Please tell me it (MJ2 V12 wasted spark solution) will NOT require two VR sensors
to get this working!
The SAW delay circuit solution currenly available requires two VR sensors
right now but mounting two VR sensors exactly 60deg apart on the front of
many of the stock Jag V12 cars is very tough to do.
Post
Correct. Only one sensor will be required.
_________________
Post
COOL!!! color me drooling for a solution!
BTW, Is your Megajolt2 a product that will not see customer availability until late this year or early next year?
Or are you looking at something sooner than that?
Post
OK Brent, it's been two days....
What's the big news? Question Smile
