For my Citroën AX GT, with 1.4 engine, Solex 32/34 Z2 2-stage carburetor and Kentcams PT02 camshaft (284 degrees) I'm using the next ignition mapping. With this setup, it delivers up to 98,5 HP at 6.000 rpm and 132,6 NM torque at 4250 rpm.
Yesterday, when I was creating a mapping for a friend with an AX Sport, I noticed I made a mistake in this mapping. I took the wrong values for the vacuum advanced, they are doubled. But since it is working good, I will not change it.
Citroën AX GT
Citroën AX GT
- mjlj-factory-adv-sheet-AX_GT.xls
- Mapping used on Citroën AX GT 1.4
- (53.5 KiB) Downloaded 760 times
