What brand of tachometer works with megajolt?
I've tried using a TIM one and it doesn't appear to work, however it was second hand and I can't be sure it works at all.
It's meant to work off the negative side of the coil on a distributor run ignition car, would placing the wire that usualy goes there to the megajolt tach out pin make it work?
Well, im looking to buy a tastefull tachometer that definatly works with megajolt, any suggestions?
Tachometer
What you have should work via the coil pack. If it is like most Tim gauges I have seen it will have a cylinder selector on the back. Hook the feed up to the coil pack connections from the EDIS module and flick the switch between settings and see if the gauge matches reality. Some of the TIM gauges will work off the EDIS module/Megajolt tacho feeds but I don't know whether that is just some of them, most of them, all of them or what.
www.trigger-wheels.com
