wiring question
eds911915
wiring question
Post by eds911915 »
how can i use megajolt to power up a fuel pump relay. iv got alot of un used pins at the megajolt ecu. is it a bad idea?
cng1
Post by cng1 »
Whilst in theory you could use one of the programmable outputs to trigger the fuel pump once the engine starts cranking it isn't something I'd recommend. Is there any reason you don't want to just connect the fuel pump to the ignition switch?
www.trigger-wheels.com
