wiring in a hidden kill switch
Craigorypeck
Post by Craigorypeck »
Hi can i just put a 2 way latching switch on the power out to coil wire from a megajolt with rev limiter to stop the car being started or will it still operate in limp home mode? I understand that without rev limit the MJ and edis 4 take a common 12v supply but the rev limit version has the power to coil via mj???
been a few years since I installed it and cant remember the specifics! Still going strong tho!!
Hi Craigory,
Sorry for the late reply. sounds like you're putting a switch between the coil and it's power source. If you interrupt the power to the coil the engine will not start under any condition.
Let me know if that answers your question!
