Just switched over to an AT&T SIM card for greater coverage, using the 5GB Data Sim, user of [email protected], PASSWORD of CINGULAR1, and host of wap.cingular.
I get the carrier detected, AT&T can see the device registered, however no data is being transmitted from it. SIM works fine.
Anything I'm missing here?
AT&T Issues
- Contact:
AT&T Issues
Last edited by James Crivellone on Fri Aug 09, 2013 9:08 pm, edited 1 time in total.
R3VLimited / Accuracy Automotive Racing, ICSCC Pro3 Cars #160 and #13
- Contact:
Update: Apparently wap.cingular is being phased out for data sims, hence why it was not working.
switched to a new apn of broadband without any other details and it connects fine via my test smartphone, will toss it back in the racecapture tonight and see what it does.
EDIT: Appears to only be Edge atm on my test phone, either way I have an uplink. Going to toss it back in the car here shortly and see what happens.
Last edited by James Crivellone on Fri Aug 09, 2013 9:09 pm, edited 1 time in total.
- Contact:
Tested and confirmed
If you purchase an AT&T Data Only SIM you need to set the APN to "broadband" no user, no password.
Worked great all weekend, ran into an interesting issue when reading and writing configs though, for some reason it would constantly wipe out my Telemetry settings whenever I made a change elseware
Att APN settings
I too am having the same issues with ATT. I spoke with them today about the correct APN Host and settings. So this is what I was told. That the APN Host wap.cingular settings as listed on the telemetry quick start are correct if your device is a 3g or older device. However if it is 4g device the APN host is only phone all lower case without a user name or password.
I will try the new apn host this evening and will post with the out come.
