Hard Cut Rev Limiter installed but not working.
RonanVauxhallNova
Post by RonanVauxhallNova »
I installed my hard cut rev limiter board into the case. I ran the coil wire from the COIL-POWER pin on the megajolt to the middle pin on the coil.
Does anyone have any idea what I am doing wrong?[/b]
Vauxhall 1400 16v megajolt 120bhp
Not Anumber
Post by Not Anumber »
Is it not powering the coil or is it not breaking the connection when the rev limit is reached ?
RonanVauxhallNova
I have the limiter feeding the coil, it just won't break the power when the limit is reached.
Hi RonanVauxhallNova,
Can you post a picture of the wiring between Megajolt and the hard rev limiter board?
Also, when you connect the Megajolt up to your computer, does it show run-time activity? RPM, advance changing, etc?
