Spark cut at high rpm?
demby123
Post by demby123 »
Spark cuts out at 5500rpm( Used a timing light to check it). Soft rev limit set at 7200 rpm, with no hard rev limiter installed. Does the EDIS really have no built in rev limiter? I can't really figure out why it would cut at that rpm...
Video
http://youtu.be/4UwTzCyCgJQ
Alex B
Post by Alex B »
How rigid is your VR sensor brakcet? Might be it starts to vibrate at 5500rpm and that syncronisation isn't established again before rpm is down to ±1500rpm.
Alex
demby123
Post by demby123 »
After a bit of research that's what I thought may have happened. I'll have a go at solving this problem when I get my distributor seal kit this weekend. The sensor is a modified stock distributor with a 72-2 trigger wheel and the original pickup sensor
demby123
Post by demby123 »
Solved it, it still misfires, but at a much higher rpm
Glad you mostly figured it out. How many cylinders is the application? The upper rev limit for EDIS-4 is about 8000 RPM, max - less for EDIS-6 and 8.
