what watt bulb ??
SSDD
what watt bulb ??
Post by SSDD »
Hi all, What watt bulb can the circuitry handle, im thinking of using a 12v LED & a 21watt 12 volt bulb for the shift light. Would this be ok or would it overload the components \ circuit board
Steve
She's a bit fat, but DIESEL fitter
Paratime
Magic Smoke
Post by Paratime »
The shift light output is controlled by a 2N2222 transistor. It is rated at 800mA max for the metal can style, the plastic are a little less, as I recall. Because it is probably in an enclosed space with no air flow, I wouldn't run more than 400mA through it. With the alternator running, 15 volts is not unheard of. Sooooooo.....
P=I*E
I=400mA
E=15V
P=400mA*15V= 6 Watts
Except for the ones that are brighter than the sun, LEDs use less than 100mA. Should be no problem. The shift light will have to be driven by a small relay, or it will only blink on, followed by a small puff of smoke from the MjLj. I would also use a clamping diode or a resistor on the relay coil, for extra protection against the voltage spike when it gets switched off.
SSDD
Thanks Mate, so what your bas
Post by SSDD »
Thanks Mate, so what your basicly saying is "NO" shall i just use an LED then ??
Thanks Again
Steve
smoke = bad :)
I would recommend using a high brightness LED for your shift light. with a proper current limiting resistor it'll work great.
Josh_b
shiftlight wiring
Post by Josh_b »
hello,
could someone put together a little shiftlight wiring diagram, as it doest just seem to be a simple case attaching an LED to the shiftlight output,
cheers
Paratime
Lights, camera, thrown rod!
Post by Paratime »
You can use pretty much any light you want for the Shift output. All that is required is the addition of a small relay to boost the signal. Any electronics store will have a suitable part. The only specification is a 12 volt input, with a coil resistance of 75 ohms or better. For example, DigiKey has part# Z140-ND for $2.70. The coil is rated at 360 ohms, so it will only draw 42mA, well below the 400mA max. The output contacts are rated at 12 Amps max, so you could run up to a 180 watt bulb. If you don't notice that, you have other problems.
To wire in the relay, attach one side of the coil to Ignition voltage (key on), and one of the two "contacts" to Ignition voltage. Now attach the other side of the coil to the Shift wire (pin 12). Finally, attach one wire from your light to the other "contact" on the relay, and the other wire from the light to ground.
When the shift wire is energized, the relay will turn on, and current will flow through the lamp. The relay protects the MegaJolt from the high lamp current.
As I stated before, I would also put a 300 ohm resistor across the coil terminals of the relay, to suppress any voltage spikes.
Paratime
LED 1, 2, 3!
Post by Paratime »
Sadly, there is no single LED diagram, since LEDs come in a variety of voltages and operating currents.
This page:
http://www.superbrightleds.com/led_info.htm
has a web calculator for finding the proper resistor for your particular LED. Use 14 volts for the supply voltage, and then you need the forward voltage (this is the operating voltage for a particular type of LED) and the operating current.
When you get the resistor value, go buy that resistor, and wire thus:
Attach one leg of the LED to Ignition voltage. It has to be the positive leg, but if you get it wrong, nothing will be damaged, but the light, won't.
Next, attach one side of the resistor to the other side of the LED.
Test the LED by momentarily grounding the other side of the resistor with the key on. If no light, switch LED leads.
Finally, attach the other side of the resistor to the Shift (or other Program output) wire.
FUN!
greypride
so..
Post by greypride »
im just trying to get my head around this...
So i can use a led shift light using the megajolt output with out a relay if i have
12v> resistor for LED> LED> Megajolt shift light connection
If i want to use a bulb, i must use a relay
is this correct?
Oliver Sedlacek
Yes, that's it. By the way,
Post by Oliver Sedlacek »
Yes, that's it. By the way, many LEDs wont take a reverse bias of 12V, so connecting them the wrong way round will blow them. Another option though is to drive two LEDs in series, so you've got 12Ign, resistor (try 560 ohms), LED1, LED2, Megajolt shift pin.
Hey presto, twice the light.
Exactly right on the LED.
It can be possible to do the same with an incandescant bulb, you first need to measure it's current draw directly using a meter or, estimate it based on the rated wattage.
Volts X Amps = Watts
Amps = Watts / Volts
So if you have a 5W bulb running at 12v it would draw about .417 Amps. That's right near the capacity of the user defined outputs.
But you should want to use an LED because it's response time is so much faster than a incandescant bulb- no element to heat up. :)
ZetecXR2
Standard LEDs?
Post by ZetecXR2 »
Would a 12v standard LED (One with a resistor built in) be ok? Obviously the in-built resistor is the correct one for a 12v supply, and in a car you can see 14-15v max. Could I still use this type of LED without a resistor, without turning my MJLJ box into a smoldering lump?
Paratime
How much too much, is too much?
Post by Paratime »
The 12v LED will have a maximum voltage rating from the manufacturer. The actual maximum voltage will be 10-20% higher than this, to allow for manufacturing irregularities. So, counting line loss, and the .3 or so that the CE junction drops, you're probably fine. Of course, just to be safe, I'd put a couple standard diodes in the line, to suck up an extra 1.4 volts.
