Megajolt/E for running a BMW M52?
Posted: Sat Feb 21, 2015 1:09 pm
Firstly, Hello! This looks like one very very handy forum.
So for my first post an awkward question: I'm building/installing a propane fed BMW M52 engine aka E36/E39 vintage.
Fueling wise I've already been running a standalone simple closed loop vaccum propane system that uses 1 lambda sensor to trim the fueling if necessary although crucially it doesn't need it to run so doesn't rely on any electronics.
This sums up what I'm after. Simplicity and the ability to be repaired or adjusted quickly during competitions in harsh environments rather than outright poke.
This system can deliver more than enough fuel at the right rates for a 2.8litre M52 engine.
But that "just" leaves the ignition. I've always planned to use a Megajolt but now that I'm looking more into it there's a few questions that remain:
The M52 being a coil on plug engine, I'm guessing to run a Megajolt/E I'm going to have to convert it to the EDIS coil system? If anyone's done this before I'd love to know what leads and mounts were used to prevent tracking. I've yet to get dimensions etc of the coil/plug orifices...Will do shortly.
It's still got it's standard trigger wheel and sensor on the front which I guess will be a BMW 60-2 unit. I've read that the megajolt can be run with such a trigger wheel but I'd love to hear it from the horses mouth so to speak.
Finally I need to drive the VANOS solenoid. (This is a single VANOS engine) Originally this is one of the things that made me think go Megajolt, the RPM based 4 channel outputs.
However VANOS needs to be switched more than once throughout the rev range. I'm guessing the Megajolt unit can't do this per se and I'll have to use 2 channels and a set of interposing relays to produce a signal that is brought energised at for example at 2000rpm but is switched back off 4000rpm?
Any help would be gratefully received and faithfully applied!
