Should I just leave this wirings out?
bugty
Post by bugty »
Hi
I am wiring Megajolt V4 to my VW Squareback 1500cc type 3 Fuel Injection replacement of its distributor, below of the distributor is triggering contacts(2 contacts) with 3 pins connector out to controller unit, the manual says that this trigger reads the engine speed and controls injectors as 1 & 3 are injected when theirs valves open then injector 2 & 4 injected and store at ports vise versa.
My question : Should I just leave this wirings out or need some kind of adapter or modification my Megajolt or else???. Please somexpert help me out ,
The fuel injection system needs the trigger from the original coil. Since you now have two coils, you will need an adapter to combine the signal from both coils. This may help you:
http://autosportlabs.net/MJLJ_V4_vehicl ... back_pulse
cheers,
bugty
Post by bugty »
Thanks for responding,
I'll give it a try.
