Reply to topic Page 1 of 1
Tach adaptor 6cyl wasted COP
Post Tach adaptor 6cyl wasted COP
Im in the process of getting the tach working on my 6cyl wasted COP system. Am I supposed to put a signal from each spark outputs to the adaptor?
I.E. Coil1 = spark A, Coil 2= Spark B, and Coil 3 is spark C?
Can someone verify.
Post
Maybe the image will help, again, 6cyl wasted spark, would I use a signal from Spark a for coil 1, spark b for coil 2 and spark c for coil 3 and leave coil 4 alone? Any help would be great.
Post
That device is what we offer for combining tach signals into one. It works with most all tachometers; there are a few old outliers that still have problems. Is it a particularly vintage / old tachometer?
_________________
Post
I was going to use it on a 78 280z tach, but I just upgraded to a autometer. according to schematics I've seen, in order to use the tach on a wasted spark system, you have to combine the three spark signals into one with diodes. I thought this would be the solution im looking for since it looks like it does the same think in a easy wiring solution. Is this correct?
Post
Yup, it should do the job for you!
_________________
