1900cc honda motor...SOHC
hondalude86
Post by hondalude86 »
Engine Mfg: Honda
Engine Code: ET2
Cylinders: 4
Displacement (cc): 1900cc
Rev Limit: 7.5k
TPS or MAP: MAP
Boosted or Normally Aspirated: NA
If Boosted- max Pressure (KPa): (at high altitude, highest KPa reads at 86kpa when the car is off
Modifications: Dual Weber 45DCOE, 285i/e w/12mm lift, 11.5:1 compression 4-1 Header with 2.25 collector. No Head mods
Chassis: AB1 (1986 Honda Prelude)
Notes: At high altitude (5300ft-10000ft above sea level)
hondalude86
well, here is the map i'm running right now, and its kicking ass, probably could use more advance up top, but here it is anyway!
A20-DCOE-CB-07302011.mjlj
A20 ITB ideal map adjusted for Altitude
(786 Bytes) Downloaded 1251 times
808asianeering
Post by 808asianeering »
hondalude86 do you have a diagram on how you wired the mj into the oem honda wiring?
i am doing an f23a sohc project and was wondering if you could help me with the setup...
thanks in advance
We build CORRECTLY for COMPETITION;
NEVER for CONVENIENCE or CONVERSATION...
