Reply to topic Page 1 of 1
MegaJolt on Chrysler Magnum 5.2/5.9 V8
Post MegaJolt on Chrysler Magnum 5.2/5.9 V8
Hello!
My V8's ECU is not programmable and has no knock detection (93 Jeep ZJ).
I would like to use MegaJolt to give me more spark advance to improve performance. I have built my engine with higher compression than stock and with good quench characteristics.
Here is my ideal setup:
1. I retain the stock ECU to run the injectors and other functions.
2. I disconnect the coil and use Megajolt as my replacement coil input.
3. I tap the Chrysler Crank Position Sensor (Hall Sensor), and Cam sensor.
4. Bolt one or two knock sensors to the block (the empty dodge engine mount bolt holes seem ideal -- no?)
5. Tap other sensors - ???
I will need MegaJolt to tap the crank sensor so that the stock ECU can get a good signal out of it too. The stock ECU must continue to think it is doing its job.
What is the future of MegaJolt please? Are these features likely?
I am an embedded C/C++ software developer by career -- but have always had boards built by the-guy-in-the-other-cubicle. So I have never built boards myself. But if programming is involved it would be no problem for me to do this work.
