RaceCapture and aftermarket wideband O2 sensors
bdon22
Post by bdon22 »
Does the new RaceCapture support aftermarket wideband O2 sensors? Eg. Innovate LC-1, AEM UEGO, PLX, etc. ?
2006 Subaru WRX
gizmodo
Post by gizmodo »
The sensor is typically a Bosch or NTK sensor. What you are mentioning is the controller for the sensor. If you're asking if the RaceCapture supports them, as long as they have an analog output, which most of them do then yes, it is supported. You would hook up the analog output of the wideband controller to one of the analog input of the RCP and then configure the analog input using the application.
bdon22
Post by bdon22 »
gizmodo wrote:The sensor is typically a Bosch or NTK sensor. What you are mentioning is the controller for the sensor. If you're asking if the RaceCapture supports them, as long as they have an analog output, which most of them do then yes, it is supported. You would hook up the analog output of the wideband controller to one of the analog input of the RCP and then configure the analog input using the application.
I'm referring to the new kickstarter RaceCapture since I didn't see any ports for it.
2006 Subaru WRX
gizmodo
Post by gizmodo »
You would need the RaceCapture Pro for that.
bdon22
Post by bdon22 »
Thanks for the reply.
2006 Subaru WRX
