Have RaceCapture pro installed in my Lotus. Everything works perfect, bluetooth to a Kindle, everything shows up, telemetry shows me moving around the track, I see my car on Podium. Unit is connected to car by OBD plug.
I have no lap times showing up, can see the car moving on the map but no lap times on the dashboard or podium.
Also on the dashboard the only gauge that seems to work is battery.
Anyone have any Ideas????
Thank you!
Lap times not working, nothing on dash but battery.
Hi gunpilot, my first guess is you haven't added your tracks to RaceCapture's configuration, so RaceCapture can't do lap timing because it doesn't know what track you are at. Follow the instructions here: https://wiki.autosportlabs.com/RaceCapt ... ace_tracks
Ryan Doherty
Autosports Labs
Autosports Labs
Have you added your OBDII channels in the configuration screen? We have docs here: https://wiki.autosportlabs.com/RaceCapturePro2_OBD2
That's my first guess.
If you want we can take a look at your configuration, either upload it here (but remove your device ID from the file) or email it to us at [email protected] and we can verify things are setup correctly.
Ryan Doherty
Autosports Labs
Autosports Labs
