GPS not working
Posted: Tue Sep 13, 2016 4:02 am
Hey Guys,
Hoping someone has dealt with no GPS signal from your RCP2?
I recently sent in my RCP2 to get repaired for a bad USB port... should have put a cable restraint on the USB cable. When I hooked it back up along with my new GoPro wifi module, everything seemed good; bluetooth is working, got my 1 analog ch, RPM, Gforce but no GPS. Believe me, it took me 2 weeks to figure that it was because no GPS that my Racerender file didn't have the autocross course map or speed information. I thought it was operator error somewhere in SoloStorm when it is really operator error/RCP2.
I will say that orignally, the kit was installed at a local shop. I figured that since I was just reconnecting cables that I would be okay to do this myself. I did confirm that GPS antenna cable is firmly reconnected. The GPS LED is putting out 1 slow blink at maybe a sec interval. When I USB tether my laptop and open RCP software it shows O GPS data. I also get the same thing on android phone when I open Solostorm, it shows 0 satellites. I went through the Quickstart at the WIKI and didn't see anyting about Scripting so I'm guessing scripting isn't a priority as far as troubleshooting. But just in case, There was a gear ratio script on the box. Which I replaced with another one that is at the WIKI:
--Developed by Luther Lloyd III 8/22/14 for use by Autosport Labs Community
--Copy this text into the scripting window of Race Analyzer
--Edit the gear ratios to mathc your car
--Add another gear row if needed for 6th gear or delete extraneous ones
--below values are constants for the vehicle
local _1stGear = 3.5
local _2ndGear = 2.7
local _3rdGear = 2.0
local _4thGear = 1.4
local _5thGear = 0.9
local FinalDrive = 3.21
--diameter in inches
local TireDia = 25.0
--allowable error of gear ratio to allow for measurement variation
local gearErr = 0.1
local rpmSpeedRatio = 0
--initialized to 0 so if it doesn't work you know
local gearPos = 0 --this is the gear channel variable
function onTick() --updates gear position every second by default
--assumes Pulse Input channel one is for the RPM signal and speed in MPH
local speed = getGpsSpeed()
local rpm = getTimerRpm(0)
--this part only works for firmware version 2.0 per the RCP page
gearId = addChannel("Gear",5)
if speed > 10 then
--makes sure your rolling so as not to divide by 0
rpmSpeedRatio = (rpm/speed)/(FinalDrive*1056/(TireDia*3.14159))
if ((_1stGear - rpmSpeedRatio)^2) < (gearErr^2) then gearPos = 1 end
if ((_2ndGear - rpmSpeedRatio)^2) < (gearErr^2) then gearPos = 2 end
if ((_3rdGear - rpmSpeedRatio)^2) < (gearErr^2) then gearPos = 3 end
if ((_4thGear - rpmSpeedRatio)^2) < (gearErr^2) then gearPos = 4 end
if ((_5thGear - rpmSpeedRatio)^2) < (gearErr^2) then gearPos = 5 end
else gearPos = 0 end
setChannel(gearId, gearPos) --outputs to virtual channel
end
I did go through a check list based on the WIKI quickstart and confirmed everything was set and at the correct MHZ. I also made sure to UPDATE everytime I made a change in the RCP software.
When I have time, I will confirm that the antenna module cable did not get cut. After that I'm guessing a firmware update to try to reset the box? I'll try to figure out how to spit out the diagnostic report on my next update.
thanks in advance
Tane
local gearErr = 0.1
if speed > 10 then
end
thanks in advance
Tane
