Author |
Message |
cwilson
 wi fi
NO and NO. I see a constant green blinking from the unit while it's on the USB. When connected to the OBD in the car it is often green/yellow..
All the active wi fi's on my Mac are neighbors or myself. Everything else is history and out of range.
Tue Jan 10, 2017 2:05 am |
cwilson
 wi fi
No and no. Grn while on usb/mac; grn/yellow while on obd/android
Tue Jan 10, 2017 2:06 am |
Oh, I have a strong suspicion of what's happening. You need to upgrade your firmware to 2.10.2.
Use your Mac to upgrade your firmware to the latest 2.10.2 - it's the link at the bottom:
https://podium.live/software
The instructions for RaceCapture/Pro are essentially the same: https://www.youtube.com/watch?v=LAFb-EeiXy8
Let's check it again after you update firmware.
_________________ Brent Picasso
Tue Jan 10, 2017 2:15 am |
cwilson
 Firmware update
Firmwaree 2.10 couldn't load: Failed to load firmware.None type object has no attribute'join'
Tried it a couple of times w/o success.
Tue Jan 10, 2017 4:40 am |
Ok, thanks for trying that. That's not what it should be doing. We will double check the firmware updater on OSX. Got a Windows machine by chance you could try it on?
Tue Jan 10, 2017 5:16 am |
cwilson
 wi fi
I do and I'll give it a try after downloading RC.
Tue Jan 10, 2017 5:35 pm |
cwilson
 wifionl windows
I was successful in downloading RC and the 2.10.2. RC opens and appears to work fine on the windows USB. It does not show a RC wi fi but it does show an unnamed wi fi I haven't seen before:" Hidden Network - secured". However I've not been successful in joining this network with my password
Tue Jan 10, 2017 7:02 pm |
cwilson
 wi fi on windows
Do I need to input the numbers after RaceCapture as part of it's name into the wi fi network?
Tue Jan 10, 2017 7:04 pm |
Good on the 2.10.2. That will fix the crashing seen when plugged into OBDII.
Now on to WiFI -
* Do you now see a blue blinking light on RC when connected via USB?
* what do you have for your current configuration?
* what does it show up under the system status? Specifically, does it show "AccessPoint Enabled" ?
Tue Jan 10, 2017 7:26 pm |
cwilson
 rc wi fi
Sorry I don't see any blue light anyway I try it. Not on the windows, Mac or Android.
What do you mean by current configuration: Im using my home wi fi and attempting to use RaceCapture 3352...?
The only wi fi networks I've noticed new on my windows unit is "Hidden Network-secured" and "Hidden Network-unsecured". However, I've not been able to connect the RC SSID to either one.
Tue Jan 10, 2017 8:14 pm |
Thanks.
What's the answer for the 3rd question- when you plug in via USB and go to the status screen - what does it show for WiFi status?
Tue Jan 10, 2017 8:16 pm |
cwilson
 wi fi on windows
My status screen doesn't show the wi fi status, it just shows Application log and Application version. I don't find any wi fi status screen?
Tue Jan 10, 2017 8:26 pm |
Sorry, I meant checking using the app on OSX or Windows, while connected over USB. Then, it will be able to read the WiFi status *from* RC - that'll help us understand if RC is successfully able to create an Access Point with it's WiFi interface.
Tue Jan 10, 2017 8:42 pm |
cwilson
 wifi conf on windows/usb
The windows computer is working off my home wi fi and that wifi name is entered in the Client mode with password. The switches are also on in Access mode . The screen does show a BLUE arrow in the top right corner blinking? The RC unit still shows green.
The Access Point switch is turned on and it shows RaceCapture 35239383620 in the SSID with no password shown. I've tried my password several times but it still doesn't connect. Maybe I've forgotten the correct pswd, but I've tried several with no success. The blue arrow in the top right corner shows regardless of what screen you're in RC. There is no Racecapture wi fi showing up, but there is a Hidden network, secured that shows up. I've been trying to use that for the RC but no luck so far.
Again, status: Access point disabled;Client point enabled, disconnected
Wed Jan 11, 2017 5:16 am |
Using your windows or OSX computer, could you please:
* connect via USB
* read the RC configuration
* save it to a file
* zip it up
* and attach it to this thread? If you'd prefer, you can email your config to [email protected]
I'd like to load it into a RC that I have here to see if I can reproduce your issue.
if your status screen shows "Access Point - Disabled" then you won't be able to connect to RC.
Let's focus on fixing that that so you can connect successfully.
Thanks for helping us work through this; I'm making notes so you we can make some more concise troubleshooting help.
Wed Jan 11, 2017 5:26 am |
