Reply to topic Page 1 of 1
Big endian txCAN
Post Big endian txCAN
Hi all,
How do you send CAN messages that are more than 8 bit long in Big endian format?
I am trying to send can message to my AEM Infinity ECU and can send 8 bit messages but I'm struggling with 16bit. I want to do this to allow for AEM native logging which allows me to create math channels in AEM data
Also any idea of how to send signed messages?
Post
You can extract the high and low bytes with some bitwise operations:
Code:
x = 0x0102 --(257 in decimal)
low = bit.band(x, 0xFF) -- mask out high byte
high = bit.rshift(x, 8) -- shift high byte to the right
println('x = ' ..x)
println('low = ' ..low)
println('high = ' ..high)
and the output:
Code:
[lua] Gracefully stopping Lua Task
[lua] Destroying Lua State
[lua] Initializing Lua state
[lua] memory usage: 16KB
[lua] Starting Lua Task
[lua] Loading script. Length: 206
x = 258.0
low = 2.0
high = 1.0
[lua] Successfully loaded script.
Hope that helps!
_________________
Post
Excellent thank you Brent,
I'm trying to emulate AEM's vehicle dynamics module using the RCP. So far my code looks like this but I'm still unsure of how I would create a 32bit message using bitwise. See attachment for description of message.
initCAN(0, 500000)
tickRate = 10
function onTick()
lat,lon = getGpsPos()
speedmph = getGpsSpeed()
--speedmph = 1.00
--altitude = getGpsAltitude()
quality = getGpsQuality()
sats = getGpsSats()
year,month,day,hour,minute,second = getDateTime()
xg = getImu(0)
yg = getImu(1)
zg = getImu(2)
xy = getImu(3) --yaw
yy = getImu(4) --pitch
zy = getImu(5) --roll
--lowlat = bit.band(lat.0xffffffff)
--midlat = bit.rshift(lat.
lowspeed = bit.band(speedmph,0xFF)
highspeed = bit.rshift(speedmph,8)
lowalt = bit.band(altitude,0xff)
highalt = bit.rshift(altitude,8)
lowxg = bit.band(xg,0xFF)
highxg = bit.rshift(xg,8)
lowyg = bit.band(yg,0xFF)
highyg = bit.rshift(yg,8)
lowzg = bit.band(zg,0xFF)
highzg = bit.rshift(zg,8)
lowxy = bit.band(xy,0xFF)
highxy = bit.rshift(xy,8)
lowyy = bit.band(yy,0xFF)
highyy = bit.rshift(yy,8)
lowzy = bit.band(zy,0xFF)
highzy = bit.rshift(zy,8)
--msg0 = {lat%256,lat/256,lon}
msg1 = {lowspeed,highspeed,lowalt,highalt}
msg2 = {sats,year-208,month,day,0,hour,minute,second}
msg3 = {lowxg,highxg,lowyg,highyg,lowzg,highzg}
msg4 = {lowxy,highxy,lowyy,highyy,lowzy,highzy}
--txCAN(0, 655360, 1, msg0)
txCAN(0, 655361, 1, msg1)
txCAN(0, 655362, 1, msg2)
txCAN(0, 655363, 1, msg3)
txCAN(0, 655364, 1, msg4)
end
Post
The script below is verified to send Racecapture Pro2 Canbus data to an AEM Infinity 506 to simulate an AEM Vehicle Dynamics Module. The only channels that are not transmitted are:
latitude (unsure how to send a 32 bit message)
longitude (again unsure how to send a 32 bit message)
GPSTrueCouse (don't believe RCP has this channel to send)
With all the other data logged by the AEM Infinity I can now create Maths Channels with AEM data!!
initCAN(0, 500000)
tickRate = 100
function onTick()
speedmph = getGpsSpeed()/0.01
sats = getGpsSats()
course = 20/0.01
xg = getImu(0)/0.000244141
yg = getImu(1)/0.000244141
zg = getImu(2)/0.000244141
yaw = getImu(3)/0.015258789 --yaw
pitch = getImu(4)/0.015258789 --pitch
roll = getImu(5)/0.015258789 --roll
lowlat = bit.band(lat,0xFFFF)
midlat = bit.rshift(lat,8)
highlat = bit.rshift(lat,16)
higherlat = bit.rshift(lat,32)
lowspeed = bit.band(speedmph, 0xFF)
lowcourse = bit.band(course, 0xFF)
highcourse = bit.rshift(course,8)
lowyaw = bit.band(yaw,0xFF)
highyaw = bit.rshift(yaw,8)
lowpitch = bit.band(pitch,0xFF)
highpitch = bit.rshift(pitch,8)
lowroll = bit.band(roll,0xFF)
highroll = bit.rshift(roll,8)
steering = 50
msg0 = {higherlat,highlat,midlat,lowlat,lon}
msg1 = {highspeed,lowspeed,highalt,lowalt,highcourse,lowcourse,sats,quality}
msg2 = {quality,year-208,month,day,0,hour,minute,second}
msg3 = {highxg,lowxg,highyg,lowyg, highzg,lowzg}
msg4 = {highyaw,lowyaw,highpitch,lowpitch,highroll,lowroll}
end
Post
Hi all,
was wondering if anyone has an idea how to split a 32bit message into 8 bit sections for Can transmission.
Regards and thanks,
Des
Post
Didn't verify it but can you try the following:
lowlat = bit.band(lat,0xFF)
midlat = bit.band(bit.rshift(lat,8),0xFF)
highlat = bit.band(bit.rshift(lat,16),0xFF)
higherlat = bit.rshift(lat,24)
Please come back with the outcome of this!
www.facebook.com/RaceElectronic
Post
Hi MikeD,
thanks for the help. I gave the code a shot but using printl within Racecapture to verify if the code was splitting Latitude into 8 bit segments but no luck. I'm not sure if Lua allows for cascaded commands
Post
Hi Des,
what do you mean when you say that you tried but no luck?
Tested what I suggested with some generic numbers and it gave me correct results...so the cascaded commands as well as the bitwise operators seem to work correctly as they should and splitted a bigger number into single bytes.
Code:
tickRate = 30
lat = 0xFDFCFBFA   -- (results in 2147483647 decimal)
lowlat = 0
midlat = 0
highlat = 0
higherlat = 0
function onTick()
  println("lat       "..lat)
  println("lowlat    "..lowlat)
  println("midlat    "..midlat)
  println("highlat   "..highlat)
  println("higherlat "..higherlat)
end
setTickRate(tickRate)
and the results...
Code:
lat       2147483647.0
lowlat    250.0
midlat    251.0
highlat   252.0
higherlat 253.0
Can you post some numbers/results/screenshots of whatever you think doesn't work on your end?
Post
initCAN(0, 500000)
tickRate = 1000
function onTick()
function splitWord16(value)
return bit.band(value, 0xFF), bit.rshift(bit.band(value, 0xFF),Cool
end
function splitWord32(value)
return bit.band(value, 0xFF), bit.rshift(bit.band(value, 0xFFFF),Cool, bit.rshift(bit.band(value, 0xFFFFFF),16), bit.rshift(bit.band(value, 0xFFFFFFFF),24)
end
--function onTick()
--lat,lon = 16777217,68500
sats = getGpsSats()
lowlat, midlat, highlat, higherlat = splitWord32(lat)
lowlon, midlon, highlon, higherlon = splitWord32(lon)
lowspeed, highspeed = splitWord16(speedmph)
lowalt, highalt = splitWord16(altitude)
lowxg, highxg = splitWord16(xg)
lowyg, highyg = splitWord16(yg)
lowzg, highzg = splitWord16(zg)
lowyaw, highyaw = splitWord16(yaw)
lowpitch, highpitch = splitWord16(pitch)
lowroll, highroll = splitWord16(roll)
msg1 = {higherlat,highlat,midlat,lowlat,higherlon,highlon,midlon,lowlon}
msg2 = {highspeed,lowspeed,highalt,lowalt,highcourse,lowcourse,sats,quality}
msg3 = {quality,year-208,month,day,0,hour,minute,second}
msg4 = {highxg,lowxg,highyg,lowyg, highzg,lowzg}
msg5 = {highyaw,lowyaw,highpitch,lowpitch,highroll,lowroll}
txCAN(0, 655360, 1, msg1)
txCAN(0, 655361, 1, msg2)
txCAN(0, 655362, 1, msg3)
txCAN(0, 655363, 1, msg4)
txCAN(0, 655364, 1, msg5)
println("latcalc "..(higherlat*16777216)+(highlat*65536)+(midlat*256)+lowlat)
println("xg "..xg*0.000244141)
println("lowxg "..lowxg)
println("highxg "..highxg)
println("xgcalc "..((highxg*256)+lowxg)*0.000244141)
end
Post
Made some more progress on splitting Longitude into individual bytes by using code above. This data is to be transmitted to my AEM Infinity ECU. I think my issue is I don't know how to create the conversion to 32 bit float with degree referencing. Please see extract from AEMnet pdf. Anyone got any ideas?
Post
I realize this is an ancient thread -- did you ever figure this out?
I'm trying to transmit GPS data to an AEM CD7 dash, although I don't need to adhere to their (AEM) protocol.
I will need to send signed values, though.
Post
It should work fine. Here's a script we have used to simulate SmartyCam data from our early testing, should get you started: https://gist.github.com/brentpicasso/0ccfb49690e8de6f98c216e80c86694c
_________________
Post
* Are these values big or little endian?
* Are these values automatically signed?
For example, it looks like speed is split into two 8-bit words (total of 16 bits). It looks like you are sending speed1 and then speed2, which I guess is little endian?
Post
It's being sent little endian, and the sign is automatically encoded. If you look at the lua script, you can see how it send the order of the bytes, illustrating how it's little endian.
_________________
