Lua scripting IDE?
davef_dci
Lua scripting IDE?
Post by davef_dci »
Howdy,
new to RC and Lua Scripting. a quick question for experienced Lua Scripters. Do you simply type your program into word, notepad or do you use some sort of an integrated development environment to enter your programs and check for syntax, etc. before uploading to RCh
So when my scripts get big I just work in a text editor and quickly ctrl-a/ctrl-c and switch over to the app and do a quick ctrl-a/ctrl-c. That's usually works fairly well in most cases.
TXBDan
Post by TXBDan »
Notepad++ has LUA script syntax highlighting. Helps a lot.
jeffmcaffer
Post by jeffmcaffer »
VS Code (https://code.visualstudio.com/) has a nice Lua extension (gccfeli.vscode-lua). Light, fast, ...
Pro3 #24
Small things, but the latest beta 1.10.1 has an number of fixes in the Lua window that makes it a bit easier to use.
davef_dci
Post by davef_dci »
Just following up on this. I've been using Zerobrane:
https://studio.zerobrane.com/
It will spot syntax errors which makes debugging easier. I copy the program and paste it into the script window.
Brent, not sure if this is a bug but I keep having an issue on my RaceCapture App where the scroll doesn't work in the script window so I can't down-arrow to the bottom of my program - the cursor simply walks out of the window but the program doesn't scroll so I can't edit or see any of my program other than the top lines. If I reboot the unit this fixes itself for a while but then resorts to this behavior. Not sure why. Annoying but not fatal and possibly user error.
Dave
gizmodo
Post by gizmodo »
Try the mouse wheel.
davef_dci
Post by davef_dci »
Unfortunately, I can't. No mouse on the android tablet and when using my computer I have a computer that amazingly has only one USB port which I need to use for the USB connection to Race Capture. If I use a USB splitter, to provide another port, the data transfer to Race Capture fails - I think Brent is aware of this issue.
I suspect my problem is unique.
Dave
Dave, on the latest app you should be able to arrow down / up and have the text window position follow the cursor. Can you double check you're on the latest version?
Anyone else seeing this problem with the Lua scripting window?
