Hondata Script error - addChannel "Speed"
radixms
Post by radixms »
I copied the Hondata script provide in the wiki which seems to work.
I tried to add a channel to pull speed from the Hondata CAN and I receive an error with the defining the Speed Addchannel command.
---I am receiving the error below.
Startup script error: ([string "..."]:21.0: attempt to call global 'addchannel' (a nil value))
Failure: Failed to load script.
If I omit the spdId definition the script runs with no problems.
Below is the script used, copy from Wiki page, only added the Speed channel variable and callout.
--This example adopted to Hondata KPro4 CAN output
tickRate = 30
--the CAN baud rate
CAN_baud = 250000
--CAN channel to listen on. 0=first CAN channel, 1=second
CAN_chan = 0
--add your virtual channels here
rpmId = addChannel("RPM_", 25, 0, 0, 9000, "RPM")
vltId = addChannel("EcuVolts_", 10, 1, 0, 20, "volts")
iatId = addChannel("IAT_", 1, 0, 0, 100, "F")
ectId = addChannel("EngTemp_", 1, 0, 0, 150, "F")
tpsId = addChannel("TPS_", 10, 0, 0, 100, "%")
mapId = addChannel("MAP_", 10, 2, -15, 25, "PSI")
injId = addChannel("InjPW_", 10, 3, 0, 100, "ms")
ignId = addChannel("Ign_", 10, 0, -20, 20, "D")
lmdId = addChannel("AFR_", 10, 3, 0, 2, "lambda")
knkId = addChannel("Knock_", 1, 0, 0, 15, "count")
camId = addChannel("CamTime_", 10, 0, -20, 20, "D")
spdId = addchannel("Speed_", 25, 0, 0, 200, "kph")
function toF(value)
return value * 1.8 + 32
end
function toAFR(value)
return value * 14.7
end
function toMPH(value)
return value * 0.62137119223733
end
--customize here for CAN channel mapping
--offset/length in bytes?
--format is: [CAN Id] = function(data) map_chan(<channel id>, data, <CAN offset>, <CAN length>, <multiplier>, <adder>)
CAN_map = {
--did not bother logging gear speed and target cam angle
--added Speed to 1632.
[1632] = function(data) map_chan(rpmId, data, 0, 2, 1, 0) map_chan(vltId, data, 5, 1, 0.1, 0) map_chan(spdId, data, 2, 2, 1, 0, toMPH) end,
[1633] = function(data) map_chan(iatId, data, 0, 2, 1, 0, toF) map_chan(ectId, data, 2, 2, 1, 0, toF) end,
[1634] = function(data) map_chan(tpsId, data, 0, 2, 1, 0) map_chan(mapId, data, 2, 2, 0.0145037738, -14.7) end,
[1635] = function(data) map_chan(injId, data, 0, 2, 0.001, 0) map_chan(ignId, data, 2, 2, 1, 0) end,
[1636] = function(data) map_chan(lmdId, data, 0, 2, 0.00003051757, 0, toAFR) end,
[1637] = function(data) map_chan(knkId, data, 0, 2, 1, 0) end,
[1638] = function(data) map_chan(camId, data, 2, 2, 1, 0) end
function onTick()
processCAN(CAN_chan)
processLogging()
end
function processLogging()
if getGpio(1) < 1 then
startLogging()
else
stopLogging()
end
end
--===========do not edit below===========
function processCAN(chan)
repeat
local id, e, data = rxCAN(chan)
if id ~= nil then
local map = CAN_map[id]
if map ~= nil then
map(data)
end
end
until id == nil
end
--Map CAN channel, big endian format
function map_chan(cid, data, offset, len, mult, add, filter)
offset = offset + 1
local value = 0
while len > 0 do
value = (value * 256) + data[offset]
offset = offset + 1
len = len - 1
end
local cv = value * mult + add
if filter ~= nil then cv = filter(cv) end
setChannel(cid, cv)
end
initCAN(CAN_chan, CAN_baud)
setTickRate(tickRate)
boggie1688
Post by boggie1688 »
Look at the addchannel syntax. You added something, and its has one too many.
Actually, you have a lower case 'c' - it should be addChannel.
