wiring again!!?!
mattwynn
wiring again!!?!
Post by mattwynn »
Has anyone got a definitive wiring guide or can tell me where to find one for the MJLJ ver 3 with TPS to edis etc.
Matt
neilthewheel
diagrams contradict
Post by neilthewheel »
The diagrams submitted by svein contradict each other. mjlj_3.JPG says wiring facing board. EDISv3.GIF says wiring facing harness.
which is correct.
Neil Worsfold
Caterham 7
MartinM
Post by MartinM »
http://homepage.ntlworld.com/steve_rand ... mjlj_3.JPG is correct.
On the other diagram, the "Connectors are shown looking into the wiring harness" applies to the EDIS components, not the MJLJ. On the actual main EDIS module, the number 1 end and the number 12 end are clearly marked on the wiring harness plug.
neilthewheel
EDIS Pinouts
Thanks for that.
On the pinout for the EDIS4, pin 11 is shown going to the revcounter. My EDIS4 has 12 pins but the plug only has 11. The position for pin 11 is blanked off. Is that because I have used a plug from a vehicle without a revcounter and should I continue looking if I want to drive a revcounter.
Neil Worsfold
Caterham 7
MartinM
Interesting (!)
Post by MartinM »
Interesting (!)
I have two EDIS modules; both have pin 11 missing. I've no idea what engines they came from.
The theory is that you drive the rev counter from the MJLJ - the bottom right pin as you look at:
SRandle
Pin Outs
Post by SRandle »
I see you all have been using my drawings from my tiger build.
The edis plug pin 11 was also blanked off. But you can take the plug apart and reuse the pins.
Not sure what site I got the info from but the edis powers my ETB gauges from Tiger very well and appears accurate.
Here is a link to the edis info from ford.
http://www.dainst.com/info/edis/edis.html
At the time of buiding everyone was on about diodes etc from coil pack. Version 2 & 3 now different Transistors.
Steve.
