Is it possible to play sound?
Rotmilky
Post by Rotmilky »
The automated start scripts for logging which use either speed (getGpsSpeed) or acceleration (getAccel) work most of the time, but sometimes they either trigger when I don't want them to, or they don't trigger at the start when I expect them to. This is usually my fault (like I've exceeded 10 mph on the way to the start line). That said,I would like to play a small audible tone when logging is started and logging is stopped just to be alerted that it's working when I want it to and when it's logging when I don't want it to.
As far as I can tell from the Lua scripting guide, there are no sound control capabilities available. However, maybe I missed something so I thought I'd double check. Anyone know if there is some way to play a sound?
Worst case, I'll implement an LED indicating when it's logging.
gizmodo
Post by gizmodo »
The RCP doesn't have sound, but there is a simple way you could do what you're attempting. You could get a small speaker and a relay for the speaker. Hook one of the GPIO pins to the relay's signal pin and then when you start logging briefly energize the GPIO port.
