Toyota Celica 18R-G
Post Toyota Celica 18R-G
MJLJ installed successfully to 1981 Celica 2 litre twincam 18R-G engine with dual 40 DHLA Dellortos. I'm using MAP setup, and after a short test drive the manifold vacuum signal seems to be strong and not fluctuating too much.
No major problems, except tach won't work etc... but thanks to the info on this website, we all know how to fix it Smile
One open question; Should I be able to use my old timing light which I used before with points and dizzy? Actually I tried two of them and either would not flash. I even verified the operation on other car, where they worked ok! Strange...
Post Timing is everything
Some timing lights won't work with one of the two plug wires on a twin coil. Try the other wire, as well as clipping on the pickup forwards, and backwards. I have occasionally needed to partially pull a plug wire off the plug, to make the spark larger. This lets the output voltage rise higher, sometimes required if the timing light pickup is not very sensitive.
Important point! Unless they have a special setting for distributor-less systems, dial-back type timing lights will not show the correct timing if the dial is set to anything other than 0 degrees.
I've just signed up. have a 77 Celica 18r g just fitted mjlj and am quite clueless so far. Have an imported config to get me going. Cool
Cheers
Neil
representing 1stgencelica.com (moderator)
View user's profile Send private message Visit poster's website AIM Address
Nice! Let's see some pictures of your car and installation! Very Happy
Founder, Autosport Labs
that's the max of 3 pics The edis and the coil are tucked nicely in the corner at strut tower and firewall. One note, that the coil is an aftermarket version of the Ford. It allows regular size wire boots to be used instead of custom made units with the OE large clip type. Cheap too at $20 (ebay or Amazon). Box is in the glove compartment. Sensor mount is a complete home made oddity that I'll post again. But it works.
Car is an 9 year continuous task that's nearly finished. MJ is working beautifully!!
Cheers
Neil
 Description:
 Filesize:  128.66 KB
 Viewed:  2345 Time(s)
 Description:
 Filesize:  175.41 KB
 Description:
 Filesize:  160.16 KB
Post couple more pics
a few more for possible clarity
 Description:
 Filesize:  75.28 KB
 Viewed:  2343 Time(s)
 Description:
 Filesize:  106.27 KB
 Description:
 Filesize:  119.83 KB
