Reply to topic Page 1 of 1
Lambda, fuel flow rate and fuel consumption - OBD2 PID?
Post Lambda, fuel flow rate and fuel consumption - OBD2 PID?
Hi guys,
Does anybody know the PID/channel for lambda, fuel flow rate and real time fuel consumption? Ive tried in several cars the list below but it has not worked:
https://en.wikipedia.org/wiki/OBD-II_PIDs#cite_note-formula-3
Thanks again,
_________________
Felipe
Post
Hey Brent, would yoube able to help on this? Thanks!
_________________
Felipe
Post
Hi, those sound like non-standard (non SAE) PIDs? If so, you'll need to get that from the OEM - or from reverse engineering elsewhere. Non standard PIDs won't be listed on that page.
_________________
Post
Actually they are standard SAE OBD2 PID, using th website above. For example, RPM is PID 12. It is waht i find on RCP. And fuel rate would be 94, however it shows nothing. Would you have any tip?
_________________
Felipe
Post
If the ECU does not respond with a value, then that means the ECU does not support that PID. It's important to remember that ECUs may not support all PIDs.
_________________
