Hi Everyone,
I have RaceCapture/Track (firmware 2.12.0) installed in my 2005 330ci and can read coolant temp, oil temp, air temp, RPM, TPS, fuel level, and steering angle.
I'm not getting any data for the brake, clutch, and cruise switch using the E46 preset configuration.
Does anyone have any ideas?
E46 CAN Mapping Questions
I have an E46 M3 and also get nothing for the E46 preset brake, clutch or cruise switch reads
I know my car won't have brake pressure over CAN but it should have the brake switch...
I also had to change the TPS and RPM from 10Hz (pre-configured) to 25Hz to get them to work properly
I tried flicking through different setting on the clutch switch with no luck so far...
Re: E46 CAN Mapping Questions
Hi guys,
sorry to wake up the topic again.
Did anyone manage to pull up lambda readings from canbus?
I need to monitor my lambda readings and would be sad to buy new lambda gauge just for this when I already have MK2 wired on canbus.
Thanks in advance
Thanks in advance
I don't believe Lambda information is available from the E46.
If you get a wideband air-fuel gauge that has CAN bus, then you can wire it into the 2nd CAN bus network on RaceCapture and map the data that way.
Hope this helps,
Hope this helps,
