Min/Max values inside of dashboard gauges
Post Min/Max values inside of dashboard gauges
Hey Brent,
I often which i could check what a max temperature was while out on track. It'd be cool if there was a small numerical display inside the dashboard gauges that could be set to record min/average/max gauge values.
Dan
Kind of like a peak hold? Or a min/max hold? That's a good idea. Thanks for the suggestion!
IŽd appreciate two options:
1. An indicator of the min/max values in the Analogue graphs for an adjustable time. For example last 5 seconds.
2. A dashboard with the min/max values of the lap or session. Best if the conditions of this min/max values could be set. For example Oil pressure at 3000rpm and Oil temp at speed >60mph for 5 seconds
Additionally IŽd like to have a configurable Dashboard with just Digital values and no analog graphs.
Harald
Hi Harald,
Good suggestions, we will make a note of it!
