MON08 connector?
Chris Morriss
MON08 connector?
Post by Chris Morriss »
I have a SOFTEC USB programmer/debug-interface I use at work for the HC908 family. This uses a MON08 connector to the target processor. The documentation does show the connections that need to be made to use it with a KX8 version of the 908. Has anyone tried to use a MON08 connection to the micro on the board?
thanks,
Chris Morriss.
rondefly
Trigger Wheel
Post by rondefly »
Is there any way to use a 60-2 tooth wheel for the EDIS and can I use the chev coil on plug system?
Thankyou
Ron Triano
Not that I know of- the EDIS
Not that I know of- the EDIS system won't be able to handle the signal coming from that wheel. It needs a 36-1 wheel.
Probably the same with the coils - you're better off running the coil packs.
brent
