map sensor replacement
Post map sensor replacement
i have a mjlj and the map sensors gone faulty where can i either get a replacement or how do i go about wiring in a 3 wire 2 bar map sensor? any 1 done this?
View user's profile Send private message Send e-mail Yahoo Messenger
Hi Chris,
How do you know the MAP sensor is faulty? Just want to make sure it's not something else.
The Map sensor is a Freescale part MPX4250AP - you could probably find it at Maplins in the UK, or you can purchase the MAP sensor conversion kit from us here (Assuming V4 controller)
http://www.autosportlabs.com/mjlj-conversion-p-50.html
it has mas fluctuation in its readings all a sudden at think over its almost at ful vac tand flicks full to 0 all though the rev range!
That's crazy! What happens if the map sensor vacuum line is disconnected while the engine is running?
it says it on full vacum then if u start pullin a vacum with a suringe it flutates all over the place!
Post Adding MPS
I have a TPS board, can i add this part to this board to have a MAP version. I have a Spitfire Mk IV so MAP is my preferred option.
 Description:
MegaJolt MOBO
 Filesize:  232.54 KB
 Viewed:  2108 Time(s)
Yes. You just need to install the MPX4250 AP with the port facing down (towards the board). Secure the MAP sensor with a small zip tie or bolts.
The port will extend through a hole that needs to be drilled in the end plate of the unit.
Hope this helps,
