GTIspirit wrote:If logging automatically starts when in dashboard mode what would for the LUA script commands
and
to work?
It would be nice to have autologging capability instead of using the dashboard display mode to trigger a recording session.
I tried this and while the isLogging() returned a 1 and 0 with startLogging() and stopLogging() respectively, along with corresponding info "Logging started" and "Logging stopped" there doesn't appear to be anything on the RCTrack2.
@brentp am I correct in guessing that the saved Session Recording that occurs when entering Dashboard mode is saved on the connected device? So if I enter Dashboard mode with connected tablet or PC, that recording session is saved on either the tablet or PC?
So if I install the Raspberry Pi dash, the recording session is saved on the Pi? Is there any way to manually control the session recording when in Dashboard mode? Since recording is triggered somehow, maybe that hook or API could be available to Lua? So then there could be dashboard visualize and dashboard record mode.
What I'm trying to do is use the same dashboard switch used to trigger the Garmin Virb recording to start/stop the recording session so the data and video are largely aligned.
