Sensors?
Speed2k
Sensors?
Post by Speed2k »
Hi, My friend uses your RaceCapture Pro Mk 2 on his car and suggested that I consider your RaceCapture/Track. I'd like to be able to monitor my Oil Pressure and perhaps my Oil Temperature. Does the RaceCapture/Track have the capability to add these sensors at all? This system would be used in a 2008 Honda S2000. Thanks
Canyonfive
Re: Sensors?
Post by Canyonfive »
Speed2k wrote: Mon Aug 17, 2020 8:15 pm Hi, My friend uses your RaceCapture Pro Mk 2 on his car and suggested that I consider your RaceCapture/Track. I'd like to be able to monitor my Oil Pressure and perhaps my Oil Temperature. Does the RaceCapture/Track have the capability to add these sensors at all? This system would be used in a 2008 Honda S2000. Thanks
I believe your 2008 uses canbus so you can pull a bunch of stuff from that. Anything else you need you can add an analongX to and put any 4 analog sensors onto the canbus as well.
Speed2k
Re: Sensors?
Post by Speed2k »
Canyonfive wrote: Tue Aug 18, 2020 9:23 pm
Thanks Canyonfive, yes, it is canbus, but from my research the OEM oil pressure sensor is a very basic on/off type system and doesn't actually supply any meaningful data. So, the RaceCapture/Track does not have the ability to even add one sensor; AnalogX though https://www.autosportlabs.com/product/a ... interface/ can connect to RaceCapture/Track (does it connect wirelessly?). Then add one oil pressure sensor [https://www.autosportlabs.com/product/1 ... re-sensor/][/url] and one linear temp sensor https://www.autosportlabs.com/product/l ... re-sensor/ and I should be good to go? If I buy a gauge and it comes with sensors, I can use those ones as long as they have linear mapping right? (I would consider the MTX-D https://www.summitracing.com/int/parts/inn-3913 because my friend has a new one that he wants to sell, but the caveat is it's likely the thermistor isn't linear)
Canyonfive
Re: Sensors?
Speed2k wrote: Wed Aug 19, 2020 1:20 am
In the sensor setup you can account for some nonliterary if needed there are 5 positions.
The AnalogX would go in line and you would scratch off the termination bridge. So ECU(terminated) > Analogx > Racecapture(Terminated). You should also add a steering sensor for the huge amount of wonderful data it provides. (You can look up how can bus works later and the termination thing will make more sense. )
Speed2k
Re: Sensors?
Post by Speed2k »
Okay, I suppose I'll have room to add up to two more sensors as well, so I'll look into the steering sensor; I don't see a "steering sensor" on the sensors page https://wiki.autosportlabs.com/RaceCapturePro_Sensors, is this something we need to source externally?
Also, does anyone know if there's going to be a newer AnalogX coming out soon? It's out of stock now.
Re: Sensors?
Hi, we are very soon launching the new AnalogX, which will feature a ruggedized enclosure for a more plug and play experience.
The new AnalogX will have a companion CAN hub, to allow it to integrate with RaceCapture, providing a complete solution.
Both of these will be launched together very soon. Watch our blog and the forum for updates.
Speed2k
Re: Sensors?
Post by Speed2k »
brentp wrote: Sat Aug 29, 2020 7:24 pm Hi, we are very soon launching the new AnalogX, which will feature a ruggedized enclosure for a more plug and play experience.
Awesome! Thanks for the update, I'm looking forward to this.
