Hi Autosport Labs team,
The Bluetooth on my RaceCapture/Track MK3 won't come up. Bluetooth is enabled in the config, but the unit never detects the module. WiFi, GPS, CAN and IMU all work normally.
Unit details
Model: RaceCapture/Track MK3 (RCT_MK3)
Firmware: 2.24.1 (official, the latest release)
Purchased in 2022 from PFTuning
What I've tried
Confirmed the firmware is the latest release
Ran resetConfig from the USB console and rebooted. The behaviour didn't change.
Unplugged USB and vehicle power for 30 s and powered back up
Scanned from a phone. The unit's Bluetooth does / does not appear
Status over USB (getStatus / getConnCfg)
"bt":{"init":0}
"btCfg":{"btEn":1,"name":"","pass":""}
Setting the name and PIN with setConnCfg returns rc:1, but reading them back still gives blank values.
Debug log (setLogLevel 7, viewLog) after a reboot
[BT] Setting baudrate: 115200
[BT] Probing module JDY-31
[BT] Probing module HC-06
[BT] Detecting baud rate 230400
[BT] Setting baudrate: 230400
[BT] Detecting baud rate 9600
[BT] Setting baudrate: 9600
[BT] Could not detect device using known baud rates.
[BT] Failed to communicate with device.
[BT] Restoring to target baud: 115200
[BT] Failed to provision module. A client may already be connected.
No phone or other device was connected to it over Bluetooth during this test.
The module doesn't answer at any baud rate the firmware tries. That looks like a hardware fault to me, or possibly a module this firmware doesn't support. Could you advise on next steps or start a repair/RMA? I can send the full boot log or run other diagnostics if useful.
Will Koscielny
Mk3 no Bluetooth
Return to “RaceCapture/Track Operation”
Jump to
- Autosport Labs
- ↳ General Discussion
- ↳ News and Announcements
- ↳ New Project Suggestions
- CAN Devices
- ↳ ShiftX2
- ↳ AnalogX
- RaceCapture App
- ↳ RaceCapture App Operation and General Q&A
- ↳ RaceCapture App Bug Reporting / Feature Requests
- CAN bus and OBDII integration
- ↳ CAN mapping discussion
- ↳ OBDII PIDs discussion
- RaceCapture/Pro | RaceCapture/Apex | PodiumConnect
- ↳ RaceCapture/Pro introductions
- ↳ RaceCapture/Pro General Q&A
- ↳ Sensors
- ↳ Hardware and Installation
- ↳ Lua Scripting
- ↳ Telemetry
- ↳ Bug Reporting
- ↳ Feature Requests
- RaceCapture/Track
- ↳ RaceCapture/Track Introductions
- ↳ RaceCapture/Track Operation
- ↳ RaceCapture/Track Installation
- ↳ RaceCapture/Track Bug Reporting / Feature Requests
- Megajolt/E and Megajolt Lite Jr. (MJLJ)
- ↳ Ignition Map Library
- ↳ Powered by Megajolt Gallery
- ↳ Assembly
- ↳ Installation
- ↳ Operation
- ↳ Q&A
- ↳ Future Upgrades
- ↳ Bug Reporting
- ↳ Fixes/Patches/Updates
- ↳ Hard Rev Limiter
