COOLING
fikus01
COOLING
Post by fikus01 »
1 of the things that i have seen mentioned is the fact that if you up the power of the processor then you need to facilitate some sort of cooling for the processor chip!!
i used to work for cummins diesel engines and they came across this same problem and some bright spark decided to use the fuel from the tank as the cooling aid!! it was placed on the suction side of the system and sealing was important as you can imagine but its an easy possibility for future developments!!
4600cc
I'd prefer cooling using the
Post by 4600cc »
I'd prefer cooling using the in-card Budweiser hydration system!
Pmoffatt
I think a small heatsink
Post by Pmoffatt »
I think a small heatsink might be a safer bet!
