EDIS6 Coil Firing Order
AndreGT6
Post by AndreGT6 »
Does this make sense?
Thanks.
Yes, from eyeballing it that seems correct. You seem to be correctly mapping the Ford firing order to yours.
Let us know how it works out!
AndreGT6
Post by AndreGT6 »
Interesting result.
When I hooked the coil up today with 12v and a spark plug I discovered my coil pin was a different.
I've updated my graphic to show the new lay out, the pins are 1=A, 2=B, 3=C...
Question, for the EDIS to coil wiring. It shows ABC from the EDIS to pin 123 on the coil, am I too assume the EDIS fires the coils in an order of ACB?
http://www.autosportlabs.net/MJLJ_V3_ve ... stallation 6 cyl model
Thanks.
AndreGT6
Post by AndreGT6 »
http://www.gt6.ca/09/0101/index.html
Progress, progress, progres...
