another ''time out on cyliner count'' post
79lancer
Post by 79lancer »
ok ive read all the other problems similar to this and so far cant figure out why im getting it
powered up correctly, configurator is set to the right port(4) i am not using a usb adaptor im going straight from rj11 on the unit to rj45 on the laptop
any suggestions?
does it need the serial adapter to work properly?
MartinM
Re: another ''time out on cyliner count'' post
Post by MartinM »
79lancer wrote:...im going straight from rj11 on the unit to rj45 on the laptop
any suggestions?
Do you really mean that - rj11 on unit to rj45 on laptop? The rj45 on a laptop is an ethernet networking connection - not what you want to be using at all.
The normal cable is a 9-pin female D-type to rj11, where the D-type either:
- connects straight into the 9 pin male D-type serial port on the laptop
- connects into a 9 pin male D-type connector on the end of a USB adapter that then plugs into a USB port on the laptop.
Which type of cabling are you using? Did you make the cable yourself?
