I can see the ignition anvance and Kpa load with revs but don't understand what i am looking at/for with the RPM and Load acceleration.
Here is a section just as the car backfired.
Any thoughts?
55:04.5 3355 99 27 833 0 0
55:04.8 3530 99 28 741 -32 0
55:05.3 3723 101 29 1666 0 0
55:05.3 3972 98 30 1233 33 0
55:05.5 4231 99 31 1566 0 0
55:05.8 4443 96 33 1466 0 0
55:06.6 4691 98 33 -933 -66 0
55:06.3 4954 101 34 -566 -100 0
55:06.5 5181 102 34 -400 33 0
55:06.8 5425 98 35 700 0 0
55:07.3 5360 101 35 -4188133 66 0
55:07.3 4081 102 30 -25233 166 0
55:07.5 5271 30 37 -1000 33 0
55:07.8 4633 27 37 -1966 -33 0
55:08.5 3941 25 36 -2500 0 0
55:08.3 3485 41 38 -193 193 0
55:08.6 3760 98 29 0 0 0
55:08.8 3852 98 29 -200 0 0
55:09.6 3906 97 29 300 0 1
55:09.3 3932 95 30 166 0 0
I get the feeling from this data that the jolt and the EDIS is getting signals from the VR so the problem could be fuel.
any guidance please.
Run Time data analysis
Re: Run Time data analysis
Can you be a bit more clear ? Do you mean - what should I be looking for. Or do you mean, what does all this data represent ?snapperpaul wrote:I can see the ignition anvance and Kpa load with revs but don't understand what i am looking at/for with the RPM and Load acceleration.
Any thoughts?
snapperpaul
When it comes to Rev accel and Load accel what am i looking for?
and
Does this data show any bad / wrong things?
The cut and paste has pushed the data together a bit but its
Time, Revs, Kpa, Advance, Rev Accel , Load Accel and event log.
You can see that i hit the space bar after the backfire event which i am assuming is why the Rev Acceleration is minus 4 million @ 55.07.3
and
