vauxhall 2 ltr 16v xe powerd capri up and running
fodderboy
Post by fodderboy »
its running and on the road ive just got to map it propley its running on the map that the unit came with for now and seems fine (is this the map that you use brent or is it just a test map?)
cheers brent for the megajolt and if anyone has or knows where i can find a map for the xe that would be a great help
some pic links
http://img.photobucket.com/albums/v233/ ... CT0006.jpg
http://img.photobucket.com/albums/v233/ ... ure012.jpg
http://img.photobucket.com/albums/v233/ ... 004111.jpg
http://img.photobucket.com/albums/v233/ ... ed0454.jpg
http://img.photobucket.com/albums/v233/ ... CT0001.jpg
http://img.photobucket.com/albums/v233/ ... CT0003.jpg
Gorgeous engine! the pride in
Gorgeous engine! the pride in your work is evident. :)
the map I load up with the pre-built units are a variation of the turbo map I'm currently running. If you're NA it would work fine, but you would gain more resolution by expanding the whole load axis from 0 to 100 KPa.
Brent
Luca Lagonigro
Brent, it will be possible
Post by Luca Lagonigro »
Brent,
it will be possible to modify the firmware to use 100kpa map sensors? I have some Magneti Marelli units I want to use...
http://community.webshots.com/photo/344 ... 8713TPaiPt
Ivan
xe engine
Post by Ivan »
Hello
I have the same engine in my opel (vauxhall) with the megajolt unit
installed. If you would find a working map for it please let me know
I am still working out the exhaust and brakes on my car and haven't connected the unit yet to the engine.
He was running with the edis module so I presume it will work with
the megajolt.
I have tried to make a map but don't know if it is any good.
fodderboy
cheers brent i will try what
Post by fodderboy »
cheers brent i will try what you suggest and let you know how it works out
ivan i will let you know when i have a working map good to find someone else with the same engine etc which model opel do you have ?
Yes, it could be modified. Th
Yes, it could be modified. The voltage curve would have to be modified to match the new MAP sensor. Do you have any data sheets for the sensor you're working with?
Luca Lagonigro
I found the thech specs of th
I found the thech specs of the map sensor (and more) on their website:
http://www.magnetimarelli.com/racing/Sensors_2005.pdf
The part I have are PRT 03, specs are at page 5 of the PDF file.
It would be interesting to ask a quote for the PRT 06 wich is 250Kpa, it can be a nice replacement for the Motorolola unit....
Luca Lagonigro
Instead of modify the firmwar
Instead of modify the firmware, it will be possible to have a sensor selection in the PC configuration software or just a check box were to input the absolute pressure value for the sensor in use?
I think it's just a easy calculation, that will make possible to use MJLJ with any (most) Map sensors out there already on the engines or at the scrapyards with the best possible resolution .
What do you think?
Ivan
20xe engine
Post by Ivan »
Hello fodderboy
My opel is '78 two door kadett. I'm not sure that in England it isn't
named differently and I would like to know how to put a picture on here even if one doesn't have a internet adress.
I only got e-mail, am I still in the stoneage here???
Ivan
A good idea. it's conceivable
A good idea. it's conceivable that you could upload any MAP sensor curve to the controller. Calibration, if you would. :)
chriscook
I am using a mjlj with a Vaux
Post by chriscook »
I am using a mjlj with a Vauxhall XE engine. Where are your HT leads from? Are they a std fit part from something or are they a custom set?
ALso if you download the DTA software (dtafast.com/.co.uk?) there software includes a base map for a std XE.
Chris
fodderboy
hi chris at the mo im using s
Post by fodderboy »
hi chris at the mo im using some leads i made up from some hotwires from halfords with some ford zetec ends fitted on the coil pack end took off
an old set going to get a custom set made soon
thanks for the info on the base map chris i will check it out
just to add to how things are going i installed the new firmware and its working a treat much smoother in the lower rev range
Ivan
map
Post by Ivan »
Hello Did you have the time to come up with a proper map for the
20L XE engine. I completed the setup this evening and the engine
is running but is backfires in the carbs and then in the exhaust.
So I could need a basic map to start with.
This is the first evening that I had some time in 4 weeks!
My leads for the sparkplugs are OPEL ones whith ford connectors
at the coil side, easely changed.
Regards Ivan
fodderboy
ivan ive posted a map in the
Post by fodderboy »
ivan ive posted a map in the files section it is only a basic map but it is the one im using at the moment until i can fine tune it
i started off with pioneerx's 1.8 8v map and retarded it in places because of pinging
Ivan
basic map
Post by Ivan »
Hey i have found the map but help me,
I see advance9 to 0 bins and do I fil these in like
they are orderd in the donwload?
