The mini:
Motor:
Engine Mfg:Austin
Engine Code:12h
Cylinders:4
Displacement (cc):1340
Rev Limit:9500
TPS or MAP:TPS
Boosted or Normally Aspirated:NA
I'm Implementing a few pieces on engine:
->Pistons Omega "0.60 Lightned
->ConRods lightned on Swiftune
->Cams 296Sp
->CrankShaft lightned
->Flywheel lightned with 3,8kg and clutch race pad
->DropGears
->GearBox of 1275 GT
->Valves 36 x 31
->Rocker Assembly 1.5 Ratio
->Valve Springs Race
->Carburator Weber 40DCOE
->DUPLEX CHAIN AND VERNIER ADJUSTABLE STEEL GEAR SET
->Mainflow stainless freeflow exhaust
--Andre--
