after 2 years of using my MJLJ, never had a problem.
now paint my car after I have many problems. what the fuck is wrong!
the last week a have problem with the MAX232 http://www.autosportlabs.org/viewtopic.php?t=2524 RPM's and no advance time, there were only connection to the laptop and showed me just the TPS to function, replace the MAX232 and the problem was solved. everything returned to normal, but my shift light not working, I checked the wires and the voltage came, everything was alright, I thought the LEDs were burned by a higher voltage.
drive to the highway 4 days ago, I stepped on 2nd gear started, to full throttle to overtake a truck and on that, explosions hit the exhaust and the engine does not work anymore ... I checked all wires incorrectly connected, etc, was everything right, waited a few minutes, and gave him starting again, the engine started, hit a few more explosions, was accelerating and decelerating until it returned to normal, I went very slowly to my house it will fail again.
2 days ago on the highway running at full throttle against a AUDI A4T
Yesterday I went to check the electrical diagram and follow all the lines are all well, I went back to assembly the MJLJ and...SAS! the shift light came into operation
I went to greet a friend at 8km from home at normal speed, arriving at destination, MJLJ smoke started coming out ... stop the engine and take him pushing, disarmed the MJLJ and the U1 rev-limit was blown I did a bypass to get back to my house.
http://www.autosportlabs.net/Hard_rev_limiter_1.1.0
I don't know what happens, always all right, now, many problems.
