Sequential shift lights
Hi, just wondering if anyone has any pics of these installed on your dash etc, did you just mount them from behind and drill some holes through the dash or use a clear lens etc? Ta
Mine are the three red lights, L-R on my combi gauge. The lights were unused and are of high enough resistance to be driven directly by Megajolt. Easy as running three wires to the Jolt and an ignition hot to the other side of the bulbs. Blue is high beams.
- Combigauge.jpg (90.59 KiB) Viewed 17160 times
Sorry Gav I though you meant DannyPgav wrote:I meant Ken but thanks for the reply
Yes individual LED's, soldered to a piece of vero board, then hot glued to the rear of the dial face.
To prevent the light shining through the other leds, I placed then in a small tube, I think it was a cut up-biro type pen.
