I'm currently waiting for my Megajolt kit to arrive here in England, for my Mini, and I've just been out to buy all the EDIS parts I need. I'm just looking over the wiring diagrams, and would like a few things clearing up!
I'm going to use 2 core shielded cable for the vr sensor, and the pip / saw wires. Now, I'm a touch unsure where and how these should be earthed / grounded. Am I right in thinking:
*The MJ and EDIS shields should all be grounded at the same point on the chassis?
*the VR sensor shield should only be grounded at the edis pin 7, not on the sensor end?
*On the shield coming from the pip / saw wires at the MJ end, should this be connected to ground?
I found this diagram, which has been modified by another member, is this accurate? (although I need to know about the shielding on the pip / saw MJ end)
Thanks, JJ
